Really new stuff on a becoming stagnant platform...
...such information is really hard to find, but did the best I could after a good deal of searching.
http://gaminglaptopunder1000.org/msi-970-gaming-motherboard-review/
We can find the MSI 970 Gaming selling for around 80 dollars on Amazon, a similar price compared to other models with the AMD 970 chipset. We have to take into account that this price competes against the models that integrate the chipset AMD 990X/990FX with a surely better VRM and higher OC capacity, but with some improvements on networks and radio that make it so interesting.
Okay that 970 Gaming board from MSI is new. So new and by many now using a defunct
cpu/chipset combo since AMD had not nor seemingly intends to release an FX Steamroller
cpu for AM3+ boards. Probably 2016 before AMD has a discrete performance cpu again.
So no real wonder that the review sites are not just falling all over themselves to review
any newer non-APU stuff. Now that crap should be out of the way.
That site above removed the VRM sinks so a view of the VRM circuit could be seen.
That appears to be a 6 + 2 + 1 VRM circuit. I would be flat arse guessing it has digital VRM control though
I could find no real answer. No I don't believe any of that crap about 32 phases.
Copied:
MSI boards, within a reasonable limit of "luck", are "OK" for non overclockers. With Nikos they may suffer in the long run probably more failures in the VRM, but overall, it's manageable. The MSI problems starts with overclockers and unfortunately, nowdays many buy even very cheap boards (3+1 phase) and pretend to overclock on them (if my board says it supports my FX6300 and my FX6300 is black edition, then my board should overclock it!). The VRM protection of MSI is problematic. A good way should allow a large margin to overclock and a point where it's "too much" and stops the overclocking potential. MSI has a dilemma. It's easy to impose an early on "wall" to overclocking, but people want to overclock... So, her trouble, is to put a second wall, where it allows for ample enough overclock, but within the tolerances of Nikos and ensure that the overclock will be high, without Nikos failing. This is the hard part. If you throttle too soon, the overclocker will bypass the first BIOS block. If you throttle as late as the other companies, chances are Nikos will fail more than other brands that don't use Nikos.
END COPY.
So for real and in line with at least 4 other posters that MOST strongly urge against an
FX-9590 or in fact I would suggest AGAINST any FX-8core. I have seen g00gle hits for a
few MSI 970 Gaming mobos running the FX-6300 and they were doing okay. NO not
overclocked to the moon like I can do my FX-8350 but in the 4.4Ghz-ish range. Mostly
stable and without any reported throttling like MSI is prone to do with their VRMs being
less than awesome.
So for my money it would be an FX-6300 and I really lean sharply at an FX-6350 since it
comes faster from the get-go than the FX-6300 without much more real loading. Then
cool the "pee" out of it with at least a top of the line Ai0 cooler and match the faster cpu
speed of the 6 core FX processor with a very good video card and play sims pretty well.
RGone...
