JimieTheFox
- Feb 18, 2014
- Location,Location,Location
Hi everyone ( first post here on overclockers.com ) my system is
CPU : AMD Phenom II X4 960T ( Unclocked X6 [email protected]/1.325Volt )
Mobo : Gigabyte 990XA-UD3 ( rev 1.1 ) ( [email protected]/1.12Volt )
RAM : Kingston KHX16C9B1B/4 ( [email protected]//9-9-9-27//36T )
GPU : Gigabyte 7770 OC (rev 2.0)
CPU Cooler : Antec Kuhler 620 ( Coolermaster Jetflo 120mm Fan pull-in air )
Case : Supercase LX-803
PSU : LEPA N500 (500 Watt)
So today I changed my Fans layout :
I installed the Coolermaster Jetflo on the Radiator to pull air from outside the case and I changed my Top 140mm Exhaust Fan with AEROCOOL SHARK FAN BLACK EDITION and I replaced 1 of my side panel fans with the Antec fan I took out of the radiator ! ( All run on Smart Fan or they get too noisy )
My temps are ( all in Celsius and after heavy gaming )
CPU : ( Min: 31 Max: 46 )
Mobo : ( Min 30 Max:35 )
GPU : ( Min:29 Max: 56 )
If I run a prime95 blend test on the 8k tests the CPU hits 50+ degrees !
Am I in a dangerous path ? Can I continue raising my Overclock ?
