- Apr 12, 2014
I canne haz X99 OCF plzzzzzzz....
Right on bro, its going to be beastly
This may be of interest, http://www.tomshardware.com/news/asrock-x99-ws-haswell-e,27461.html Asrock's new Workstation board.
A ton as they always are. I would expect $400+ being on X99.Speculation on price? That's a beauty!
isn't pcie 3.0 at 8x the same as pcie 2.0 at 16x? i thought we were way off from needing faster than 2.0 16x. should be great for a couple gtx 980s'.
EDIT: here we go.. http://www.pugetsystems.com/labs/articles/Impact-of-PCI-E-Speed-on-Gaming-Performance-518/
" Conclusion
Our testing has pretty clearly shown that for gaming using either PCI-E 2.0 or PCI-E 3.0 will give you nearly identical performance. Oddly, in some benchmarks PCI-E 2.0 was actually faster than PCI-E 3.0. At the same time, x16 was not consistantly faster than x8. Again, x8 was actually faster than x16 in many cases. So unless you care about getting up to 1.5 FPS better performance, you might actually want to manually set your video cards to operate at x8 speeds - although we really would not recommend doing so.
This isn't to say that PCI-E 3.0 is not faster than PCI-E 2.0, or that x16 is the same as x8, but rather that current video cards and games are simply not able to utilize the additional bandwidth they provide. In fact, we recently showed that the performance of a Xeon Phi card is greatly reduced if you run it at x8 speeds in the blog post Performance of Xeon Phi on PCIe x8.
While we recommend using the latest PCI-E revision whenever possible, if your motherboard or video card only supports PCI-E 2.0 our results show that this really is not a problem. At the same time, if you want to install a sound card into your Z87 system but doing so would limit your video card to x8 speeds, that is also not a very big problem. At most you may see ~1.5 FPS drop in performance, but that change is so small that it is very unlikely to ever be noticeable."
Yeah, the 5820k (article was a typo) may be exactly what the doctor ordered. Retail is apparently expected to be around 400$ which is perfect (as long as I dont need a 500$ motherboard.....)
15mb L3
That octo-mom you're talking about is indeed expected to be in the 4 figure range, so thats not really an option for me. Probably dont need 16 threads anyway xD
edit: launch date is in 2 weeks... I can certainly wait
