Latrini, the short answer to your question is that the bios menu will *not* change at all. You'll still see exactly the same multiplier options (5x, 5.5x, 6x, ... x12above), but they won't correspond to their nominal multiplier value anymore. For example, setting 1000(100) will give you 2300 instead of 1000. But you won't see an actual 2300 setting in the bios.
Before you take out your thunderbird, you might want to set the bios to 900(100) (which corresponds to 1700 which is safe: stock frequency of XP2100+). Then turn off your mobo, take out the old tbird, plug in the new tbred, and turn the mobo back on.
I posted the following info to the alt.comp.periphs.mainboard.abit newsgroup a while ago. I think you'll find this useful:
If anyone wants to try the TBred B XP2100+ on their KT7 non A, I've compiled this multiplier mapping table (after numerous resets of the bios when system failed to boot):
500 -> no boot
550 -> no boot
600 -> no boot
650 -> no boot
700 -> 1500
750 -> 2200
800 -> 1600
850 -> 1650
900 -> 1700
950 -> 1800
1000 -> 2300
1050 -> 2400
1100 -> no boot
1150 -> 1900
1200 -> no boot
>= 1300 -> 2000 (I think the >=1300 setting corresponds to the 12.5 multiplier.)
1400/133 -> no boot
I think the multipliers 500, 550, 600 and 650 have been remapped to multipliers higher than 2400 and that's why I wasn't able to boot up. Same with 1100 and 1200.
The highest I can go and still have a rock solid system (as tested by prime95) is 2300. If I use 2400, everything seemed to work fine except prime95 gave errors. The highest I've tried is 2520 (24x105). The system boots up fine until it starts to load windows, then it hangs. I'm not sure if that's a limitation of the CPU or if it's the disk controller giving in (I suspect the latter.) Too bad AMD hasn't remapped any of the multipliers to 25, otherwise I could have run 2500 without overclocking the PCI bus.
