Mix said:
yes, that should work just fine.
M@€$†®Ö™ said:I just wanted to add a little tidbit of info into the Motherboard (KT7A) not reading the tach signal from Fan. I started to manually turn down my Thermaltake Smart Fan 2 once I hit around 2570 rpm then there were no returns of the RPM amount in the BIOS or in VIA HM. I am thinking they show as 0 at start up and you get the beep codes when enabling the Protect CPU if no Tach Signal is found on boot at such a low RPM. Please check and confirm or deny my theory and I will do more investigation into this. And I will be getting a XP2100 T-bred B in the next week or 2 to mess with in this KT7A-R V1.0
MarK
dermon said:Hi Doc,
Yup I meant clearing the bios.
please check if this is correct:
1. set multiplier to 9 and fsb to 100mhz? thus 900?
btw: what's a good 3dcard that will work on this system? (abit kt7 raid with tbred b?) I have an ATI AIW Radeon and its not stable. I plan to change it to a better card. Any ideas?
dermon
[xeno]neophyte said:doc.. when you said you maxed out at 24*105 did you mean on the kt7 or a different board?
when i try to use "user defined" settings for fsb and multiplier on my kt7 it won't boot.
--neo
docinthebox said:By the way, I was using bios A9_2.34.
[xeno]neophyte said:Also.. OC-master.. whats the inverted fsb mode for?
