jschuler24
- Apr 2, 2015
Hi all,
I have built computers in the past, but nothing as advanced as my current project. I am still working on getting the computer stable, but that may take awhile with the components I have chosen from what I have read. I want to know about the temp monitors that came with my various components. One is the Corsair Link and the other is my motherboard's program. Here is a screenshot of the two:
Which temp should I trust? The Corsair one (A) varies nearly 10 degrees while the other (B) stays steady about 5 degrees higher then the Corsair's upper temp.
Thanks,
Josh
**EDIT**
May have just answered my own question, but need some clarification. I opened CPUID HWMonitor and found that there are a few different temps, the CPU under the motherboard has the same temp as the one being reported by the motherboard software. The temp for the processor is corresponding to the Corsair temp. So these are measuring different parts of the computer. .
Thanks,
Josh
**EDIT**
