Good choices.
Only possible change is case size and price. You can save a little using Define R2 and a lot if Arc Midi will do.
Define XL R2 is a good case, but do you need a case that big? Define R4 is same design but smaller & $20.00 cheaper. Arc Midi is similar (no door or sound mat) & $65.00 cheaper.
XL R2 = 232 x 559 x 560mm; GPU 330mm; CPU 170mm;
R4 = 232 x 464 x 523mm; GPU 295mm; CPU 170mm;
Arc Midi = 230 x 460 x 515mm: GPU 290mm; CPU 180mm;
I think the biggest differences between XL R2, R4 & Arc Midi R2 are 9 vs 7 PCI slots covers (can use XL-ATX motherboard); 20mm more PSU clearance with bottom fan; and of course sound mat & door. Thing is sound dampening is really minimal with matting and door anyway. Having quiet fans is far more important.
Arctic F14 PWM are fine but might want to consider using them for exhaust too. That way exhaust fan speed up and pull more air out when system is working harder to better match airflow volume of intakes and coolers and are slow and quiet the rest of the time too. I suspect your biggest problem with be GPU fan noise.
That said, I use 3x TY-140/147 intakes and no exhaust fans, but have removed PCI slot covers and cut out rear vent grill. I just got an Asus GTX580 DirectC II. So far it's running very cool (30c idle/40c load) and CPU is only up 3c so not a problem. Will be moving everything into Phanteks Enthoo Primo next month anyway.
