Temps are already at a breaking point. Like someone mentioned above, 55C is about the limit for AMD chips before instability. If you try to stress test (not play a game) with temps playing a game at 50C, you will easily eclipse 55C...
I retract my previous statement, i completely glossed over the fact that your 50c was in a game....
dog is right, P95 will prolly push you past 55 if your at 50 just playing games....
try swapping to a better thermal compound and make sure your application is perfect, clean out any and all dust, make sure case flow is as good as its gonna get, fill in your case with any fans your case accepts if you havent already.
Make sure your case is not against a wall or trapped under a desk or anything, make sure all fans are on highest settings, and check the overheating link below in my sig to make sure your getting the best cooling you can with what you have!
