- Dec 30, 2013
So, I have been dreaming up massive air cooler designs for some reason while also searching for bargain cpu coolers. That's when I stumbled across this thing (brand new) on ebay for a mere $40 obo with free shipping:
Susanoo is a Japanese god of summer storms.
Now I know all you 'practical' folks out there will tell me how this thing will mess up the airflow of my case, and how much better water cooling would be, etc...
But look at it, it's a freaking monster. An oddity of cpu cooling that belongs in a overclocking museum or something. And I got if for $35, five more than a coolermaster evo212.
So, I'm not sure I should even attempt installing this thing-but I might. I'm thinking if I do, I will ditch the four fans for a single 200mm. Plus from what I've seen online these little 'slipstream' fans sell for about seven bucks a pop anyways. I can use those four little fans somewhere else...
Here is what I envision the best possible application for this could be other than just marveling at the thing:
APU build that has a case with a lot of mesh on the side (and one big enough this thing will fit in) so the air cools the ram and mb components in addition to the cpu- and the other case fans all blow outward. Such that all air comes in through the side, then blows over the board and then is pulled out.
Does anyone think this is actually a cooling solution that would get good results?
Also, I read that it's nearly impossible for a cooler to break the mb if installed correctly but this thing weighs 55 Oz!
Thanks in advance for the thoughts.
