Bill Dimwit
Disabled
- Mar 21, 2018
I put some thermal grizzly conductonaut on my 980ti and help it run cooler along with Thermal grizzly pads on the ram and VRM.
Oddly now that card is running 7c hotter then stock
At first I thought I made a mistake and cleaned the card off and reapplied the conductonaut, but the temps stayed the same.
I used Cool labs liquid metal a lot in the past and applied it in the same way they recommend.
Dose conductonaut have a curing time? However the temps keep getting worse, after a fresh apply of conductonaut the card loads at 63c, but after about a day the max temps are closer to 67-68c. With the stock tim the card run no hotter then 60c. Im running the fan at full speed when I load the card up.
I'm just stumped, what could I have done wrong? I can't think of anything.
