- Jul 9, 2005
- USA
Here it is ladies and gentlemen, the long-awaited step-up from the Ultra-120 Extreme!
So far I've only seen it on Sidewinder Computers website, but hopefully it'll crop up everywhere within the next week
Copied from www.sidewindercomputers.com:
Thermalright IFX-14 for Intel LGA775 and AMD Athlon 64, FX, X2, Opteron & AM2 Processors Product Description & Info
Thermalright IFX-14 for Intel LGA775 and AMD Athlon 64, FX, X2, Opteron & AM2 ProcessorspadThe IFX-14 is Thermalright's largest and most comprehensive CPU cooler to date. The IFX-14 could literally be considered a cooling system for your CPU and motherboard, as it features an additional back-side heatpipe cooler to rid of additional heat produced. As indicated by the model number, IFX-14 can support up to two 140 millimeter or standard 120 millimeter fan sizes, one of which can be sandwiched between the two high-riser heatsink towers.
Features
* Larger surface area than any other heatsinks (140mm x 120mm) with option to install one or even two 140mm fans
* Designed for better air flow management to work with the heatsink fans* and the air inside your computer case
* Four large 8mm heatpipes to distribute massive amount of heat fast and efficiently
* Optional to rotate the heatsink 90 degrees to best fit your system configuration
* Multi-platform compatible backplate for installation on vast number and type of motherboard. No need for complicated tools to convert
* Includes a back-side dual heatpipe heatsink (patent pending), which not only additionally cools your CPU but also takes care of the heat coming from the back of the motherboard to extend the life expectancy and stability of your motherboard
Technical Specifications
Heatsink Body
- Dimension : L146.2 x W124 x H161 mm (heatsink only)
- Weigh t: 790g (heatsink only)
- Recommended Fan : All 120mm & 140mm Fan
Back-side Heatsink
- Dimension : L134.5 x W163.5 x H112.6 mm (heatsink only)
- Weight : 130g (heatsink only)
- Recommended Fan : All 80mm & 70mm Fan
Compatibility
- INTEL: All Intel Socket LGA775 processors
- AMD: Athlon64 / FX / X2 / Opteron Socket AM2 processors
Installation Instructions
This is an extremely large heatsink. Using the dimensions provided above and here, customers should take time to measure and ensure this product will fit his or her motherboard and case. Not all motherboards will allow for utilizing the backside heatsink. Due to the nearly limitless motherboard and case combinations on the market, no guarantee can be made that it will fit your specific application. For more information please see our return policy.
IFX-14: $79.95
Features
Heatsink Body
Back-side Heatsink
Compatibility
IFX-14: $79.95
