- Dec 14, 2010
Choosing between the Thermalright XP-90, XP-120, and Ultima 90/90I which would you say is the best for cooling (disregarding the limited socket compatibility of the XP-90 and 120)?
Let's say for the sake of an example that they are being mounted on a socket 939 or LGA775 motherboard.
I ask because I have all three of these coolers sitting in front of me and quite frankly the XP-90 and 120 are a complete PITA to mount and dismount from a motherboard (I spent twenty minutes trying to remove an XP-120 from a 939 board yesterday without destroying the cooler itself, the mounting bracket, or the motherboard). I should mention this was with the board still in the case, because all I wanted to do was swap the cooler and didn't want to have to disconnect and then reconnect everything again. The Ultima 90 on the other hand, I can swap out within 5-10 minutes, and install in say 10-15 (depending upon socket type and other considerations).
Does the cooling ability of these XP-90 & XP-120 coolers outweigh their horribly difficult mounting systems?
I'm really trying to decide if it is even worthwhile to keep the older XP coolers anymore, or if advances in cooling technology (going up to the Ultima-90/Ultra 120 Extreme era) have surpassed their abilities so greatly that they are completely obsolete.
