most of their Air cooled products aren't horrible, some actually perform half way decent. But generaly speaking you can buy much better for the same amount of money, if not less.
Personally I'm glad to see more companies getting on the WC bandwagon, the only problem is how some of these lowercost, "entry level" systems are being marketed (cough TT cough). If you just want a virtually silent cooling solution, and don't care about extreme performance, hey fine, but you should be abel to tell what types os WC solution fall into that category. With TT, average "joe I just started getting into computer modding/overclocking" is going to think things like the Big Water, or this phallis are "performance" cooling kits.
Thats why I don't like TT. It perfectly OK to make a lower performing WC product AS LONG it is targeted to the appropriate audience. I know plenty of people who could care less about having their CPU running 2 degrees above room temp, or overclocking their system. But who would think a silent coolnig solution would be nifty.
TT seems to think they can crap in a box, slap some nifty buzzwords on said box, coat it in some LED lights, provide a rheostat, and they have a high performnce product.
