- Mar 27, 2011
- Soviet Mexico
So i am back with a new APU combo Once again going for the gold. I'll be posting progress in here as I go, as promised.
Sadly I am off to a rough start. After getting the initial setup done I didnt have any hard drives on hand so i messed around with some ram speeds a bit. Sadly I found that with the initial bios it had similar problems to the a75 fm1 boards had on release with ram stability. Timing tightness and speeds where limited for booting ability. Had sucessful boots up to 2133. Nothing in the 2400 range timing wise would boot, across 4 different sets of ram. Dominiator gt's 2400 and 2622's, and geil evo corsa's 2400, and RisjawX' 2400's.
After picking up some hard drives I installed w7 on it. Noticed that the drive controllers still exhibit poor performance outside of the OS. Yeilding Slow read and write times. I haven't tested this with one of my ssd's yet but It wouldnt surpise me one bit since the earlier hudson chipsets also had performance issues in these departments.
I ran out of time on the first night after installing everything. Since I had to head to work. So the next day when I came back I once again messed around with the board. After firing up the Easy tune software I found that the in OS core multiplier changes did not work. Also found the k8 stats will not recognize the cores for this apu. leaving that out of the equation for overclock. However the bclk was setable. Managed a mild setup overclock of 4.6ghz on default cooling with no load and no voltage changes. All voltages where locked on manual at the baseline accept for ram. Which was set to 1.65v per module requirements. (I was using my cas 10 ripjaws at this time 2x4gb).
I also found that while changing bclk frequency that cpu-z was freaking out on the ram tab, showing massive changes in timings to a degree that made no sense. (2-5-1 12 ht speed 12785) Which i attribute to be a mix of cpuz in-compatibility and bios instability. This was all on the release bios.
I had been having the bios bomb out quite a bit even on the release bios. So i decided to upgrade to the f3g beta bios. Which might I add I don't recommend. I had several sucessful boots and spend some time playing around in the bios again getting things tweaked and and re setup. I did manage to the the ram to boot at its rated speed of 2400mhz cas10. This require a marginal increase in northbridge voltage. and extremely small amount. Got back into the Os made an attempt at overclocking with the core multis again with no luck. Stuck to the bclk and managed to push the ram up to 2800mhz this time. (impressive) The failure point seemed to be inline with earlier apu experiences. It bombed out after the sync with the ram got unstable resulting in screen tearing and artifacting them a blue screen. Attempted to reboot and ran into corrupted bios image. after 6 reboots the image finally flashed back over from the secondary bios. (not the first time the bios has corrupted on this board, it seemed to be more tempermental about bios image than my old a75-ud4h was). Made some small changes here or there went back into the bios to try getting some stability out of in under it. Pulled of a clean boot then pushed for 4.8ghz. Got their and after two minutes it bombed out. Again resulting in a corrupted initial bios image again. This time there was no recovery. Flash back was incapable from the second bios. Possibily meaning that both chips in question where corrupted.
The hole time everything was under pretty much stock voltages. The error codes of 55, and b5 seemed to be purely memory releated. Despite that b5 indicates a usb host device hot plug problem.
I am gonna call gigabyte later today and see what they can tell me, aswell as any info they can give me about the lack of multi control. Possibly finess some hardware out of them to continue chasing some records with.
I also ordered another one of these boards since I probably wont see a replacement for the current one for longer than I would like to wait.
