Should I upgrade to the parts below or jump to i5/i7? I have $550ish budget.
My current rig:
Full Tower Case by ULTRA forgot model..
XFX Nforce 680i LT Mobo
Intel Core 2 Quad Q6600 @ 2.4 ghz (stock)
6GB OCZ DDR2 800mhz Memory
Western Digital WDC 500gb HD (data/games/etc. - don't remember speed but I got it a long time ago 2-3 yrs...)
OCZ Vert 64gb SSD HD (operating system)
NVIDIA GeForce GTX 280 1gb superclocked
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
750w power supply
The parts I am looking to upgrade to:
Hard Drive (Just because I need more space) - these are the same, just different sizes right?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4034139&CatId=2459
or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4538820&CatId=2459
CPU
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4089666&CatId=2758
(Might upgrade Mobo + RAM if will work better with this CPU choice)
Mobo
http://www.tigerdirect.com/applicat...details.asp?EdpNo=4394541&csid=ITD&body=MAIN#
RAM
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3984931&CatId=3361
Please post any suggestions,thoughts, or advice on parts that you would suggest to use instead of these. Basically, tear my system apart and tell me the best parts I could go for with my $550-$600 budget.
Question:
-The CPU I chose, is it overclockable? (I've read a lot of bad on OC'in my current q6600, want to make sure I don't get something I can't OC if I want to)
-Does my Mobo have anything to do with how well I can OC that CPU? If yes I will probably buy that mobo I linked..
-Will upgrading to that CPU + Mobo(supports ddr3) + ddr3 memory provide enough performance increase to justify the price of upgrading to dd3 ram as well?
-Should I go to the i5/i7/ddr3 ram/new mobo or will this be the best choice of upgrades to do for a $550-600 budget?
-Will I notice substantial enough performance boost (since everyone here says my Q6600 bottlenecks my GPU hard) by switching to this CPU?
I know it's a lot to read and I have a lot of questions, but I want some knowledgeable feedback and advice before I drop this much money >_<
My current rig:
750w power supply
or
CPU
Mobo
RAM
Question:
