Well usually bottom mounted PSU'S still have the intake on the bottom so that's not an issue
On my case I could've mounted my PSU that way, and maybe I should've. I just didn't want to have one more filter to vacuum out.
So drop a screw in it instead...seems like a good trade off to me!On my case I could've mounted my PSU that way, and maybe I should've. I just didn't want to have one more filter to vacuum out.
PSU's are bottom mounted now?
That doesn't seem like a logical choice to me.
Hope the PSU was off when the screw fell in!!!!
Flip it over. Prevents this from happening. Most quality PSUs don't need a lot of airflow. Some don't even have their fan turn on until a certain load/temperature.
Hmm. Guess it's been a while since I last had an actual PC case.
I wonder though, do bottom mounted PSU's accumulate more dust that top mounted ones?
we have bottom mounted psu's so we can shove rads in the top......
now that's sweet.
most of mine that are bottom mounted have filtersexcept the 2 corsair air540 and 240, they are on the bottom but the psu mounts on it's side.
the thermaltake core p5 i guess you might call it bottom mounted, but that's a fully exposed system case.
Are watercooled systems generally heavier than aircooled systems? Is it a significant difference?
