- May 3, 2009
Hey folks, unfortunately for you I have returned for your guidance
Quick Brief
I'm looking to overclock my 1100T once again, but this time I'm using a different brand of motherboard, "Gigabyte 990FXA-UD3 Revision 3.0" to be precise.
I've posted here before where I successfully managed to get achieve a stable overclock of 4.2Gh'z on an am2+ motherboard (Asus M3N-HT).
http://www.overclockers.com/forums/showthread.php?t=697778
With your help I am hoping to achieve the same results, if not better if possible.
CPU-Z / Temps
The problem
Currently as I have updated, I have came across settings I've never heard of, such as "Vcore Loadline Calibration", "NB, PCIe,PLL Voltage". This is proving to be more confusing than I first anticipated.
On top of that, I had the basics of overclocking before hand on my old motherboard, setting the multiplier, adding Core voltage to the CPU/ CPUNB and that was it. But now I don't really see the option to add core voltage as "1.475" but instead something like 0.475+ ( as an example)
So hopefully OC can provide an insight on what these do, and how to get myself started.
Thanks,
Ollie
Specs
MOBO > Gigabyte 990FXA-UD3 (Revision 3.0)
CPU & Cooler > Phenom II 1100T, Noctua NH-D14
MEMORY > Crucial Ballistics 1600Mhz CL8 2X4GB
POWER SUPPLY > Corsair 650HX
VIDEO CARD > 2x XFX 260GTX XT Edition SLI
HDD > 1230Gb - 1x 750Gb, 1 x 320Gb, 1x 160Gb
CD/DVD > Generic DVD/RW
SOUND > ASUS XONAR D2 PCI
O/S > Windows 7 Ultimate 64-bit SP1
Quick Brief
CPU-Z / Temps
The problem
Thanks,
Ollie
Specs
