I had another thought about olfarts problem.
One issue I did have when putting this thing together was
getting the ram dimms seated properly.
(I have done this hundreds if not thousands of times over
the last 18 years or so...Was a network admin last 10 years)
I thought I had them in OK at first. BIOS saw it all and the
windows install began correctly, but at the point where it
gets done copying and tried to load the GUI, I kept getting
windows protection errors. After a couple of trys, I decided
to check if the ram was in OK. Seemed right, but I yanked
them and reseated them anyway.
The windows install now completed. But still not OK.
Prime95 got some errors the first time I ran it. (All this at 133fsb)
So I booted my docmem ramtester program, and sure
enough it found errors.
I reseated the ram a third time, pushing real hard, and checked
the tester again. Tested OK. After that, all was ok with
windows, prime95 and whatnot, so I started the overclocking
fun.
Guess it is too late for you, but somebody else getting that
board might want to double check it.
They in good now. Passed the simmtester program at 164fsb
at cas3. (Prime95 didnt like that though....)
Re: the voltage.
The motherboard is NOT setting it back to default. If I do change
it, it changes correctly, but since it doesnt seem to need more
voltage at any of the speeds I have tried yet, why bump it up ?
I think you will like the combo Tanice, unless you get a lemon
like olfart did.....
