- Dec 6, 2002
I just ordered a Tuniq Tower 120 to replace my POS Thermaltake Mini-Typhoon.
Is it possible to use the motherboard automatic fan speed control with the stock fan for the tuniq tower? I don't want to have to mess with a rear fan speed control, I just want it to run slow when my CPU is cool and fun fast when my CPU is hot, similar to how the stock heatsink works.
I notice the stock tuniq tower fan only has a 3-pin connector and not a 4-pin connector like the stock heatsink does. The fan on the mini-typhoon was also 3-pin. There is an option in the bios to have fan speed done via voltage control instead of PWM but when I tried that on my mini-typhoon it just seemed to run it at full speed the whole time. I'd guess that is just because it is more or less overwhelmed by he heat output from the quad.
Can the stock Tuniq Tower 120 fan be successfully adjusted using the auto fan control using the voltage setting? Will it go be low RPM when the temps are low and high RPM when the temps are high? Has anyone tried this?
