New to overclocking so I think is a basic general question. This is related to something I’ve posted in the GPU forum but distinct enough I thought I could ask a different question here.
Question:
Could the my systems inability to overclock, even mildly, be indicative of a larger CPU or Motherboard issue? Or, is it likely unrelated and I just have a “less than great” CPU?
Specs:
MOBO: Asus M5A99X Pro Rev 2
CPU: AMD FX-8350
COOLER: Silverstone AR03
MEMORY: G.Skill RipjawsX 2x8 1866
VIDEO: XFX R9 290 (2)
PSU: Seasonic Platinum 1000
O/S: WIN 7 64 Bit
Details:
Normally, I have not been running anything overclocked at all. I’ve been experiencing issues running games Crossfired (if interested, the whole – way to long story – of how I troubleshot this is in the GPU forum). Giving up on the crossfire issue, I removed one GPU.
With nothing more to tinker with I went into the bios and just tried using the “Ultimate” setting from the bios basic screen. It overclocked the cpu to 4.3 GHz. After wards I ran Prime 95 and had workers fail under a minute.
I know that automatic overclocking programs are not something to trust, and that no real Overclocker would ever rely on them. But I also thought that built in programs generally do a mild and safe overclock.
After failing, I then reset everything back and then tried O.C. Tuner from the Advanced Bios Screen. I tried the AMD CPU Overdrive. I also tried just bumping the multiplier up by 1.
Temps are all low, never breaking 52c when “overclocked” and running Prime95.
All of these produced unstable results, with stopped workers (relativly quickly) in Prime95. Running with everything auto and normal, I can run prime 95 for a full work day and that night with no issues.
Does this seem normal? Do you think there might be some latent defect in the MB or CPU?
I’m just wondering if maybe the board or CPU may be bad, and could contribute to my Crossfire issues.
Thanks for any help, I appreciate any thoughts you may have.
Dave
Question:
Specs:
CPU: AMD FX-8350
O/S: WIN 7 64 Bit
Details:
Dave
