- Oct 11, 2002
- Thread Starter
- #41
Ah, yes, updates.
Well, work has been slow going. The plastic is taking a bit longer to cut than expected. Takes me about 1.5 hrs to get a single set of exhaust/intake grills cut into the plastic (distractions, such as TV, etc...heh). I am nearing the end of cutting the case. Not to mention that I'm doing this in my spare time, which I don't have a whole lot of...heh.
Anyhow, the PSU has been fit, so has the mobo. I am waiting on a slim CDROM drive to come from directron so I can cut the hole fot that and the floppy....then I need to make some mounting brackets for all of the drives. I fear that will be the difficult part. I was planning on making them out the steel I removed from my main rig when I cut the window....steel takes a long time to cut, and I can't cut the steel indoors as I have been doing the plastic....but first I have to design the brackets, and for that I need the drives.
I'm nearing completion. I am just hoping that I will be able to get all the drives in there. If the specs from directron are correct, and my imprecise measuring is correct, I should have enough room for the cd and floppy. I am a bit concerned about the HD, tho. But, with a little luck, I should be able to get it in.
Oh yea, I did have a minor setback.....broke something I shouldn't have, lol. I did manage to fix it tho, and in the end you won't even know anything had happened. I will describe the details when I post all the pics.
All I have to say is that I HOPE BEYOND HOPE that this hasn't been done before. Or else all of this secrecy and hype has been for nothing....I don't want to disappoint all of you who are anticipating the final product....heh.
