- Aug 5, 2013
- London, UK
UPDATE:
PC is all (as best my knowledge serves me) set up... but, it won't turn on, .
Basically, when I first hit the power switch, all 'lights' and fans briefly zip on, literally for about half a second, then stop dead. Then, if you try again, nothing happens... if you wait a bit and/or turn the PSU off then on, the single light flicker happens again. The green light on the MB is constantly on, which I think means power is being supplied to it correctly... so I'm really confused.
Details that may help: optical is in SATA 1, SSD is in SATA 2, old HDD (with old OS/files/etc still on it; was planning on booting from SSD, as Windows 8 is in the optical drive currently, then wiping old HDD from there) is in SATA 3; 4 case fan's 4-pins are each plugged into each other, then into one 4-pin power connected to PSU (I'm sure this should be fine, as had similar set-up on old rig).
Can't think of anything else other than a part being dead. Absolutely depressed right now.
Please ask me ANYTHING about this that may help you... i.e. how it's wired, anything to do with the parts, etc.
May take it to a shop tomorrow for assistance, as not great at solving these things myself. Thanks for the help.
P.s. Can take pics if you need them.
_____
Original post:
Hi, all.
Currently running a rig I made in 2008 which has served me honorably since then. Unfortunately, since then, I have fallen completely out of the loop with computer hardware, and am primarily a console gamer (I have a YouTube channel), and have no idea what the standard is these days, what are the best parts, and what I should buy. So, was hoping you guys could help out. Here's what I'm looking for:
Let me know if you need anymore details. But yeah, basically, I just need some help building a beast gaming + editing/recording PC for my budget!
Looking forward to hearing from you.
-P
_____
Original post:
Hi, all.
My spec is very simple, and is pretty much outlined in the title of this thread. It will primarily be a gaming PC, with the aim of running the latest games at as high settings as possible within my budget, as I want to get back into it, and add PC gaming footage to my YT channel.
It also needs to handle editing programs like Sony Vegas, and recording/rendering programs like XSplit (for which I've bought a membership, but my current computer cannot handle). For XSplit, I'd need to be able to render + stream at 720p.
As far as my research has gone, I think all the above should all be reasonably accessible for between £700 and £800. I'm looking to buy the rig in about a month/month and a half (in September), so let me know if I should wait until then to reeavulate. But, if there's no new pieces of hardware that'll be gamechangers, then let's get going now!
!!!NO PERIPHERALS NEEDED!!!
Current rig
Case: Antec 900
Motherboard: Gigabyte GA-EP45-DS3R
Processor: Intel Core 2 Duo E8400
Gfx card: HIS ATI Radeon HD 4870 512MB
Memory: GeIL 4GB 1066MHz Black Dragon DDR2
Hard drive: Samsung SpinPoint F1 500GB
Powersupply: Corsair HX 520W
-P
