You can pm them to me at your leisure as to not hijack the thread with this OT stuff. As I said, the dude you have on ignore and are responding to was talking about the cpu pushing the cards, not the scaling of the gpus themselves.
Ok I will PM you when I get a chance, but as far as his CPU even a 2600k I think should be able to scale either flavors fine, despite my anti intelnessYou can pm them to me at your leisure as to not hijack the thread with this OT stuff. As I said, the dude you have on ignore and are responding to was talking about the cpu pushing the cards, not the scaling of the gpus themselves.
Had the P95 Running for 20 hours with on 3.5Ghz with no errors, so will try adding some volts.
Nice! I've got it running p95 @ 3850, i'm a bit unsure of the temps it has an avg at about 57 and maxed at 60 and has been running 45 min
OK a quick lesson on setting things in your bios ........ we will set your ram.
First boot into BIOS and under the Extreme Tweaker tab find your find the Memory Frequency as I have highlighted. Select it with your mouse or if you are using your keyboard ..... scroll down to it and hit enter.
You will get a popup with all your speed settings. The will look different then mine so find something that is very near to your 1600MHZ and select it. Click on it with your mouse or hit enter.
YOU CAN STOP HERE IF YOU LIKE and leave the rest on Auto or you can continue and finish setting you ram.
Next scroll down to the DRAM Timing Control. Click on it or hit enter. This will bring you to your timings for your ram.
These timings will be on your ram or you can find it in your SPD tab of CPUZ. as you can see mine are set to 11 11 11 33 ..... your's will be different. Set these 4 values at what your ram is rated for don't forget to hit enter after you type in the proper value before you move on.
When this is done scroll down to DRAM Control Rate and set this to 2T ..... unless your ram says different...... hit enter.
There you are done ...... hit F10 and save your settings. Now reboot and go back to windows and run Prime for at least 2 hours or till you get errors or a failure of some sort ....... you might still have some fine tuning to do now that you have changed your settings. Watch your temps as before. If you get a failure report back ........
