Frankly, there's no easy way to tell. Older, high-quality USB cables often work fine with USB 2.0. The standard as set by the USB-IF for USB 1.1 cables was sufficient for USB 2.0 devices. Many cheap cables which did not meet the USB-IF's standards were made and sold. These seemed to work fine for USB 1.1 devices, but fail utterly with USB 2.0. Certified USB 2.0 cables should have the Hi-Speed USB logo on a tag or a plug. They may have "USB 2.0" or "Rev. 2" printed on the cord insulation. In the end, the best way to tell is to test the cable yourself.
