- Oct 31, 2002
Ive been reading these forums a lot and more and more, people are suggesting, or have been using blowers in water cooled systems. I have to admit that i am most interested in useing a blower to cool my right when i go water sometime this spring, the extra pressure that a blower can generate over a axial fan seems perfect for a system that has a lot of inherent airflow resistance, such as a typical heatercore.
I Figure that i will use a chevette core as my first core simply because there is a lot of reading material on different modding techniques. that and i already have one. got it for $15 cdn out of somones old slag car.
ill be sure to leak test it quite extensively.
now. these are all possible flow designs based on a 435 cfm 24vdc blower. it is completly plastic built. i might swap it out since there might be some concerns about the motor generating too strong a magnetic field. might cook my system.
Placing the blower behind the core, sucking air through the core, through a duct and blown out the side of the case. only problem with this, is that with the heatercore placement in mind, i would have to place another fan in my side panel to feed the case with fresh air. that fan would be sucking in hot air.
THis one places the heater core on the other side. my other 120 mm fan mount. the air is blown out the case along with the hot psu air, keeping all the hot air in the rear of my pc. the only problem with this mounting meathod is its restrictivness of my cpu water cooling components. there coudl be a space problem.
This looks like th emost logical meathod. sucking air in from the side and blowing it out the front of my case.
the system is more self contrained in this design, but placement could get tricky due to my zalman heatpipe on radeon. however, if i go water, im going full water, so my gpu will also get a block for the loop.
I have also kind of toyed with placing the system in the top of my box, but that would mean cutting away all of my cdrom bays to make room.
im using a Antec super lanboy case, would be nice to keep at least one bay able to use a cd drive.
If i was willing to put my fan external, this wouldnt be a concern at all, but i want my system to be completly self contained. i should use a standard 120 mm axial fan, but if i can minimize the noise of my setup and not sacrifice that much airflow, blower would definatly be of beneficial use. im also thinking ahead because i might want to place a pelt in my system to enhance my cpu cooling performence further. this is more of a consideration for my GPU though as it is getting more of my attention now, playing more modern games.
what do you guys think? placement is a little irridating with the short case. i will already have to cut my internal drive cage out to make room if i have to place the radiator in the bottom. putting it in the top means more mods that comprosmise my case to a greater degree.
placing it in the top also precents me from hiding my atx cables away in the top of my tower. they are all sleeved now, but still.
I would like to not mod the main structure of this case if i can avoid it, but im not completly obtuse to it.
im going to do my setup as soon as i have some money to buy basic tools. any input form pro's would be greatly appreciated.
this is the blower i want to use:
http://www.surpluscenter.com/item.asp?UID=2004030103472365&item=16-1279&catname=electric
might be severely overpowered ha ha. but it looks about right. i just need to find a reliable way to power that thing. 10 amps even might be a stretch.
http://www.surpluscenter.com/item.asp?UID=2004030103472365&item=16-1257&catname=electric
this could work too, i could just bolt it snugly to my side window.
