Sorry guys, I have to correct myself, I was wrong about thermal throthling; there is only thermal protection built in: today I discovered that this is not a fact of my Tuallie, but a Feature of my MoBo...there is nothing written anywhere in the owners manual or elsewhere mentioned that I would know, that additional auxiliary thermal probe input on my MoBo has such effect! Even if having this mobo for more than 3 years, I still discover time to time something new about it. Well this can be for me a nice & usefull feature!
@ JuMpY: >are you saying that you got your tuallie up to these temps, are you f#%kin crazy?<
)))))))))) YYYYEEEEEEEEEEEEEEESSSSSSSSSSSSSSSSSSSSSSSS !!!!!!!
with OC-ed Tuallie 1.0A@135fsb/defaultVcore & well done AirFlow thru case & very silent machine!
The max working was 88°C if I do not count 97°C for few minutes while checking calibration of
my measuring Gadget with Cpu on the desk & praying god, that later will still work in my setup!:
http://users.volja.net/jerman55/AdaptPreProtTyp.jpg with HairDryer like this:
http://users.volja.net/jerman55/HeatingFront.jpg Gadget schematics:
http://users.volja.net/jerman55/CpuDtempAdapt.jpg
All additional 3 fans in my closed desktop setup are normally running using 7V fans setup like
this-rpm sensing enabled! & the case:
http://users.volja.net/jerman55/rpmSensFan7v.jpg
http://users.volja.net/jerman55/CaseInside.jpg
During tests, fans were controlled by SpeedFan, except PSU thermalControled 6-9V one, which was running all the time. Temps are shown like this: MoBo=MoBo; Motherboard=hotest air pocket inside; Cpu=MoBo-sensor=Socket-sensor 2-3°C cooler than sensor mounted under HSF closest to IHS; (Amb+)AUX= REAL inside core temperature taken from CPUs On-Die diode!
The system was running idle normaly with additional fans @12V, than @7V, than @5V & than WITHOUT them-
this last FULL LOAD!!!
While using fans, the full load Cpu temps were just a bit /2-3°C/ higher than
on idle! Here are snapshots:
http://users.volja.net/jerman55/12vFanTemps.jpg
http://users.volja.net/jerman55/7vFanTemps.jpg
http://users.volja.net/jerman55/5vFanTemps.jpg
http://users.volja.net/jerman55/NoFanTemps.jpg
With this last the temperature of a heatsink passed 60°C, vhich diminushes using fans, but it is still about 10° less than real core temps with normal cooling, so everybody should add this value to their readings to get approx. actual core temps! I really wonder, how high are the AMDs core temps... Ouch!
if Tuallies can be so high! Any additional comments?
BTW, do you now that non-OC-ed Celly400 with only stock heatsink NO fan still normally works @80°C..
