- Jan 7, 2005
ochungry said:I dont think I understand the question. but if you are implying if there is a direct relation between vcore/vdimm increase and overclocking? there is but not a set formula or rule.
more voltage helps w/ overclocking that's about it and as far as i understand it.
From my own experience, i have learned that for every 50 mhz increase in cpu speed, you need ~ 25mv(one notch higher) vcore increase.
another word, if you increase fsb from 200x10 to 205x10 you need 25mv increase. But even this is not a set rule. Most cpu's will overclock about 20% without any vcore increase. When cpu is unstable at an overclock, then "may be then" you should increase vcore one notch and keep increasing speed until it is unstable again, and repeat the process. The 25mv increase in vcore for every 50 mhz speed increase, should be applied when highest cpu overclock is found @ stock vcore (you ran into a wall w/ stock vcore).
I hope I am making sense.
OC,
Yes, your answer was what I was implying and it's pretty much what I was seeing overclocking my old Asrock before it went out. When I was stock testing the CPU for an overclock my old Asrock board hit the wall at about 11x234 - 236 MHz and probably the vcore limit output for the board or over. 11x230 ran ok for a while.
A few RAM brands state what the vdimm specs increase with overclocks or they give you something like 2.6v - 2.9v and you figure it out from there.
