- Apr 27, 2002
- wash dc area
OH NO, my beloved ic7 that i spent all those hrs moddin out is kaput.. i smelled something then all of a sudden a got a hi vddq warning and the rig went to blue screen..so i turned it off real fast and did an inspection. i figured my prommy pulled some moisture in and burnt up somethin..but that wasnt it.. i noticed one of my vtt power mosfets was discolored and i think what happened is when it burned i got a sudden surge to the rest of the components. unlike hipro5's other 4 mods this vtt didnt go right from the beginning, even tho i did it EXACTLY as diagramed. i couldnt use a trimmer to adjust the vtt like he said, cause it burnt them up having to turn them down to like 1 ohm to get any vtt response. so u know me i just wired in a 1/2 ohm 3 watt resistor so my vtt would come up to par.. unfortunatley it was too much and now although my mb boots i only get 1 volt vtt at 2.9v(should be 1.45.) and when i try to add resisance to my vtt mod it actually loads the vtt circuit down and i get less voltage. this circuit must have 2 mosfets feeding voltage otherwise id be dead in the water. oh well, ill try to contact hipro and see if its fixable if not, since it still works maybe i will give it to someone here.
