- Jan 7, 2003
Not sure where he got that one, but it's just an agp riser. They are used for rackmounts normally. Just do a google search for "agp riser". They're all over the place.
Deadbot1_1973 said:Not sure where he got that one, but it's just an agp riser. They are used for rackmounts normally. Just do a google search for "agp riser". They're all over the place.
shiltz said:For the small widescreen monitor res if you have a Nvidia card and a Xenarc 7" then you can get the native res of 800x480 with the Nvidia drivers, you just need to set up a custom res setting in it with the info Xenarc has on it's site for doing so, if it's a Lilliput you're pretty much out of luck as the Lilliput doesn't actualy detect it's native res and will try to display at 640x480 or 800x600.
shiltz said:That's odd, it works fine with my Xenarc and Nvidia drivers, did you use this picture from xenarc's site to set it up? it's from powerstrip but it works with Nvidia drivers too.
What Nvidia card do you have, maybe some cards have issues with outputing that res properly, I have an MX4000 in mine.
flamerail said:That hd isnt gona be able to with stand the bumps a car gets... I give it 2 weeks befor the head crashes.
azu said:i thought they so ld mini hds?
hmm guess not..
