Hi, i am planning to upgrade my rig to water cooling over summer. The main reason for doing so is the unbearable noise from my crossfire setup as well as the 80 degree temps i occasionally get under load.
My case can support 280mm, 120mm and a 140mm (possibly) radiators.
I have a AMD 6350 and two MSI R7870 twin frozr cards all of which will be all cooled in one loop
My list so far:
XSPC Acrylic Dual 5.25 Reservoir/Pump Combo with One 18w Laing DDC
http://www.watercoolinguk.co.uk/p/X...rPump-Combo-with-One-18w-Laing-DDC_36846.html
XSPC EX240 Crossflow Dual Fan Radiator
http://www.watercoolinguk.co.uk/p/XSPC-EX240-Crossflow-Dual-Fan-Radiator_29045.html
XSPC EX120 Slim Line Single Fan Radiator
http://www.watercoolinguk.co.uk/p/XSPC-EX120-Slim-Line-Single-Fan-Radiator_25024.html
EK Water Blocks EK-FC7870 Backplate - Black
http://www.watercoolinguk.co.uk/p/EK-Water-Blocks-EK-FC7870-Backplate-Black_42216.html
EK Water Blocks EK-FC7870 - Acetal + Nickel
http://www.watercoolinguk.co.uk/p/EK-Water-Blocks-EK-FC7870-Acetal--Nickel_38233.html
EK Supreme LTX CSQ AMD CPU Waterblock : Nickel Acetal
http://www.specialtech.co.uk/spshop...-CPU-Waterblock--Nickel-Acetal-pid-16892.html
i will also be using these fittings:
1/4" BSPP - 1/2" ID - 3/4" OD Compression Fitting
http://www.watercoolinguk.co.uk/p/1...ID-34andquot;-OD-Compression-Fitting_828.html
and this is my case:
Cougar Challenger
http://www.cougar-world.com/products/pc_case/challenger.html
I want to do straight runs but might see if i can do it with soft tubing,
Any advice would be much appreciated, i'm new to water cooling
My list so far:
Cougar Challenger
