Alaric
- Dec 4, 2011
- Satan's Colon, US
Quick question. Is mounting the Industrial Line CPU waterblock an entirely DIY affair? Or are there brackets for different sockets? If DIY, are the dimensions available?
Please check out our HEATKILLER GPU X³ Core series: they can come as complete standalone, GPU only blocks, or can be enhanced with a micro block to additionally liquid cool the vrms. The Core itself is compatible with most cards with a standard size PCB. The MicroSW-X blocks can be equipped with a new copper plate that can be cut to fit on any vrm layout.This is my first time looking at a all purpose GPU cooler. I have owned several complete blocks for the 6970, 7950, 280X, and 290X series cards. I would like to find one that will fit at least a ATI\AMD 5xxx and up and a Nvidia 4xx and up. What would you recommend???
The coldplate is 40x40mm, the hole pattern is 52x52mm. Yes, you'd have to design and manufacture your own mounting mechanism. It also comes with a completely flat coldplate, instead of the slightly convex coldplate of our regular CPU blocks. That block is not targeted to end consumers, but to industrial customers who use it on a wide array of specialized appliances.Quick question. Is mounting the Industrial Line CPU waterblock an entirely DIY affair? Or are there brackets for different sockets? If DIY, are the dimensions available?
All our products always come with G1/4'' ports. Please see the Specs if unsure.Dear Sir,
Your link to the http://shop.watercool.de/epages/WatercooleK.sf/en_GB/?ObjectPath=/Shops/WatercooleK/Products/17000 (GPU Block Only) needs more information. I have several "Standard G1/4" threaded pumps, fittings, and radiators. Your Web Site for the HeatKiller GPU Block does not state that it has G1/4" threaded fittings that can be used on both sides. I (as a customer) would wonder if I needed to also purchase your fittings, pumps, and radiators so that everything fits.
The additional copper plate is needed if you want to install a Core on a 79X0 or R9 280X. If you want to install the Core to any other card, it is not needed.The site Mentions but does not state that an additional copper plate is needed for compatability with AMDs 79xx and 280 series video cards. Do you need it or not (is not included with the product) for the product to work with those cards??
That's pretty neat.
Our Announcement/Teaser is well received! Through all the platforms and forums, I received a ton of questions. Please understand that I can't answer everything: some things aren't finalized yet and we are looking for your feedback, some things we on't want to talk about yet to not give hints to the competition - and some suggestions from the users flat out got us by surprise! So we are still asking for your ideas, suggestions, feedback - I'll read it all!
So here's my (incomplete) list of answers right now:
- Power delivery: there will be adapter cables for SATA and Molex available, so you can chooesewhich connector suits you best.
- Heat: we are using a highly efficient system, so the components do not heat up at all. The housing is completely made from aluminum, so it can dissipate the little heat that might arise easily. The controller does not requie an additional cooler or fan.
- Software: the system will be compatible with Windows and Linux.
- Integration: we will try to integrate as many third partysensor systems as possible. High on our list: HWinfo and Riva Tuner.
- Flow sensor: at launch, there will be a mechanical flow sensor available from Watercool. The software will be perfectly trimmed to this flow sensor. We also have plans for a non-mechanical flow sensor, but it's uncertain if and when we'll ever get that to end customer market.
- Additional connections: you will be able to hook up two controllers. One will function in "slave mode" and only supply additional connectors and channels, if needed.
- Display: there will be two display units: one will be mounted in a 5,25'' bay, and the other will come with it's own external housing that can be placed anywhere within cable reach to the controller. Both units will offer a simple, intuitive input device that can control and configure all relevant parts of the controller.
- LEDs: we currently have one 3pin header for adressable/programmable RGB LEDs available. We are thinking about adding a second header, so you can even run two independent LED cycles in your system.
- Price: there is no price point set yet. It will be competitive! And given it's a modular system, you'll be able to tailor the right control ecosystem for your own needs!
We appreciate your input and support and look forward to your feedback!
