Uhm, I'm not exactly sure what your question is. To my knowledge, this pump is made by alphacool, another german company that we are not affiliated with. No, that pump will not fit on our new HEATKILLER Tube series of reservoirs. No, we do not hae another small scale pump or pump/res combination.that is nice, im not sure who actually makes this pump. PCP doesnt list the 3.6k rpm one any more
http://www.performance-pcs.com/alphacool-dc-lt-2400-low-noise-ceramic-12v-dc-pump-bulk-version.html
any chance you might be able to that pump on that res or do you guys have a smaller pump/res combo like that? i have been looking around for a pump that is cheaper since im just doing cpu cooling in the loop. alot of pumps like the D5, mcp's are just more then i need.
Yup, that's exactly how the 1080 blocks will look like.I feel like a see-through section for the actual coolant flow path coupled with a shroud on the outside makes most sense for those who want see-through blocks and also full length PCB coverage (http://shop.watercool.de/epages/WatercooleK.sf/en_GB/?ObjectPath=/Shops/WatercooleK/Products/15040 and http://shop.watercool.de/epages/WatercooleK.sf/en_GB/?ObjectPath=/Shops/WatercooleK/Products/15037, for example).
How does the de-coupling work on the reservoir multifunctional clamps? Is it a 2 piece bracket with screws in the middle or something else holding them together?
In previous GTX generations, Hydrocopper-labeled cards were usually reference PCBs, Classified-labeled cards were usualy non-reference. We guarantee our HEATKILLER® block will be compatible wih any card with a reference PCB. So, presumably, it will be compatible with the Hydrocopper, but not with the Classified. Since both cards are not released yet, we obviously haven't seen a PCB with our own eyes, so we can't tell definitely. Pleasecleck with the Compatibility list BEFORE purchasing a water block.Will the HEATKILLER® waterblock be compatible to EVGA Hydrocopper or EVGA Classified? (or any other special subbrand of any manufacturer?)
We are planning on new pump tops that will be in the same design as the HEATKILLER® Tube series. There will be a Dual D5 pump top. We are not sure if it will be possible to mount it directly to the res, as with the single D5, or if it will have to be seperate from the res. We are still open for wishes concerning pump tops, though! I myself am not convinced of multi-pumps and run a rather large loop with one single DDC1+T, so: if you wish for dual pump tops, do you wish those pumps to be in serial or in paralell?I do have a question about two pump in series solution. Have any with a reservoir in the works? Would surely keep me interested if I were to move from a dual bay res + dual pump series setup.
Thanks for the input! Our design for the next gernation of radiators acutally does take this in account. We want to make them way less restrictive!Hello WATERCOOL-Jakob,
Somewhere on this thread you mentioned a re design of your current rads...
Would the future release of those rads be less restrictive as of now they are one of the most restrictive rads out there i just wonder if that will be considered in the next batch of rads. Hopefully also without solder flux which is a major pro in my book regarding your rads since they are round tubed. Your feedback is welcome thanks in advance.
Oh, I do have one question, do the Watercool MO-RA3 radiators use O-ring seals on the internal tubes or are they soldered?
Hey friends,
I can give you the first infos and show you the first pics of the new HEATKILLER® IV for the GTX 1070 and 1080. We can waive the “XL” by now, the new water blocks are released only in this form factor that covers the whole PCB.
Of course, we have the typical HEATKILLER® IV trademarks on board. These include very low restriction and elaborate cooling structure. The central flow design ensures even further reduction of restriction.
Precut thermal pads and isolating standoffs provide an easy mounting. The stainless steel frame can be removed for maintenance. A massive piece of machined acetal ensures a homogenous and even transition between the water block and the graphics card. Another highlight hides beneath this piece…
It is now possible to install a preassembled LED-strip inside of the water block! These LED-Strips are compatible to the power supply of the graphics card. We even crimped the exact matching connector to it. Hence, it can be supplied directly by the graphics card, there are no more irritating cables.
The LED Strip can be controlled via the Nvidia Geforce Experience Tool. It can be dimmed, blink or pulsate. We offer the LED-strips as additional accessories in the colors white, red and blue.
We will release other versions of the water block. Soon, we will release a nickel plated version, along with versions with black frames. A water block with Acetal Top concludes the series. Matching eBC backplates will also be released in short time.
Of course, the new HEATKILLER® IV are compatible with the new Geforce SLI-HB bridge.
And here are the pics:
