Hi all.
I'm planning on wc'ing my first built rig. I have most of my components, but I just need a hand and some advice with selecting a few things.... any help or advice will be appreciated.
My rig:
ASUS Maximus V Formula
Intel Core i7-3770K
EVGA GeForce GTX 670 FTW 4GB - x2 SLI
G.Skill Trident-X 32GB (4x 8GB) 2400mhz
OCZ Vertex4 256GB SSD
Seagate 3.5" Barracuda 3TB HDD
CM Storm Trooper (window) case
I'm looking at this loop setup:
Res>Pump>240mm Rad>CPU>Thermo Fusion>240mm Rad>SLI GPUs>Res.
The questions I have:
1)
As far as the rads are concerned, I've been told by a lot of people that Black Ice rads are by far the best.
http://www.hwlabs.com/index.php?option=com_content&view=article&id=13&Itemid=10
I'm not too sure though of the major differences between the GTX and GTS series'. Obviously one is for a more silent build whilst the other is more performance based, but when it comes to watercooling, just how loud are the GTX versions and how much less performance is there with the GTS series??
2)
With my SLI setup, I have found these waterblocks:
http://www.frozencpu.com/products/1...ock_-_Nickel_Black_15521.html?tl=g30c311s1631
I'm assuming that I need 1 block per gpu? If that's the case, I'm wanting to cool each gpu simultaneously, where the water gets divided equally as it reaches the gpus (I think that's called a serial setup?). What parts do I need and can anyone recommend to join the blocks together and achieve this?
3)
To cool my cpu, I am planning on using this block:
http://www.ekwb.com/shop/blocks/cpu-blocks/supremacy/ek-supremacy-elite-intel-115x.html
I'm just wondering how they rate, I've read some fairly positive reviews, but it never hurts getting more info and feedback.
4)
I'm a bit unsure on what pump to use. For my loop, I've been told on other forums that a D5 pump is the way to go.. can anyone recommend any in particular as far as they go?
5)
For the reservoir, I'm keen on using a bay res. EK make the res that has the wheel that spins, are they all clear-windowed (at the front)? And also, if anyone can recommend any accessories too, that'd be great.
and 6)
I'm planning on using compression fittings, however, I'm not sure what size tubing that I need. Just something clear and that is almost unkinkable, would be great. As for the coolant, people have advised me against it. I'm pretty keen on it though, does anyone have any recommendations for a bright red, performance coolant? Something reliable that tends not to cause blockages etc?
Sorry for my MASSIVE post. I have read a lot of Stickies and many, many forums. However, I still find it hard to get simple, direct; helpful information and answers. I more than appreciate any advice that anyone can offer.
Thanks.
-Ry
Eeek, one last thing.. any recommendations as far as soundcards go??
