- Sep 27, 2004
- Wonderland
System in sig.
I'm posting this in 2 forums for maximum visibility.
I recently bought a new case, and swapped everything over to the new case because the VGA coolers I bought didn't fit in the old one.
on fresh CMOS settings (removed battery + unplugged) I get a fresh post, asking to recover bios settings. If I do anything in bios and save, I get a no video, no post, no beeps.
If in bios, I discard settings and exit it goes right to post, with video, and goes all the way into windows.
I did move the 2nd 580gtx to the bottom slot PCI-E, instead of the middle, but both cards work ,I've tested them seperately, and even with 1 card I see the same results.
If I make ANY changes in bios, I have to completely reset CMOS to get a post with video. and then it makes me go into bios to "recover settings".
I made it into windows once by discarding the settings, as said above, but all my settings had been reset. It was like I had no video drivers installed.
Is this a VGA issue with the new coolers? (they worked perfectly before I swapped cases), or a motherboard bios issue?
All things are seated, reseated, and reseated again, temps all look good. Stock settings on all as far as I can tell, and triple checked all cables. Other than swapping the coolers, the case change was the only modification, otherwise completely the same.
So I'm currently in windows on the same machine, both cards are working. But if I reboot, make any changes to bios, or do anything except hit F1 on post, then discard changes, I get black screens with no video post.
I even tried 1 stick of memory on several dimms to see if it was a memory issue, no dice.
Any ideas?
Any ideas?
