Yes it is from ASTEK , but from the looks i think its same as H80 since it has a thick radiator
But we don't have ASTEK here.
So which you guys will go for Antec Kuhler h20 920 / Corsair Hydro H80
I would really want to go for Corsair to match build.
Anyone have experience with H80 or any Hydro series and can confidently tell me you will not have problems like
1) Dies within months to a year have to RMA it
2) Pump problem , have to RMA it , can't be avoided
3) Must have fan set to super high speed , over 1500 RPM , just to cool an Intel i5 3550 @ 3.3 GHZ which not even intended to OC , during Idle and Gaming
Cause it might be only 136 $ , but im spending over 400 bucks here for them , god i will F@$# **** if things go badly
Because my idea of thinking its " You get what you paid " , so a 136 $ i don't think its cheap...its even more expensive than the Noctua nh-d14
( i would go for this if my RAM doesn't get in the way , also a heatsink this big , i don't want my Mobo go falling down on me )
Not to mention Corsair its such well known , reputed and popular company. I pay this much yet i have to face BS , that's not something i would like nor anyone else i bet.
Remove heatsinks from RAM or get low profile RAM. Cheaper than buying a new cooling system.Been sick for 3 days wasn't able to reply.
But guys , my MAIN REASON of changing from Air Cool to Closed Loop Water Cool its because,
The fan for air cool heatsink will collide with my Corsair Vengeance RAM , unless i could find a proper replacement for my TX3 EVO , i will most properly be going to Closed Loop Water Cool.
Will work, you just don't like it.I know you could just have one fan on one side instead of having 2 , but i dislike the idea and the looks of it , i prefer to have both fans on both sides.
So it won't work.
Many have done it with no problem.Also i do know that air cool could be good as water cool , but you must go for cooler big as like the Noctua NH-D14 , Cooler Master TPC 812. Which worries me damaging my Mobo , not to mention mine its a M-ATX which i think its weaker too
Water cooling and CLC systems are not known for running smoothly with no problems.I couldn't care less which is better in cooling , I just want it to be able to install into my PC without fuss or problem , have it run smoothly yet again with any problems or so. Keeping my CPU cool at a decent temperature at a quiet fan speed rate.
Than use a good air coolerSince i mentioned over and over im not doing any OC nor will I . So it's pointless even if someone install me a full set water cool system
Both have good records but air is simpler and has less chance for problemsSince there's so much complain and negative comments for Corsair i think i will either go for Antec 920 / NZXT Kraken.
Already answered by ConumdrumBut for Kraken X60 , it seems that there's some modification needed to be done if i were to be fitted on to my Carbide 400R.
Anyone have any experience with this / any idea what does this mean ??
http://www.nzxt.com/new/news_detail.php?id=318
No mention of the Krakens, eh? How rude!
AIO coolers are becoming more of a standard these days. A LOT of people are moving from air to AIO's. There's pros/cons to it, just like everything else. However, I have never had an Aircooler that was just a painless install, and in my opinion, that scores highly for the AIOs, because they're typically VERY easy to install.
You haven't used many air coolers have you... the Hyper 212+ is extremely easy to install... and so is the oem intel cooler which just uses push pins... no need to use a back plate or anything...
