- Nov 13, 2001
- NY
guys what can sensor 1 be?...
maskedgeek said:well theres no way your cpu is 1c over mobo, so imm guessing its your case and somethings up with your mobo and cpu temps...
BinarySuperman said:no mobo is my motherboard, and yes my cpu is 1 c above my mobo temp, but nvm that, cause i had my windows closed, usually its mobo - 34c and cpu - 37c, i just dont understand what sensor one is? can it be my video card?
there is NO WAY your cpu is 1c over cpu with any kind of cooling. Either it is way lower with liquid nitrogen, or at best with air cooling about 15c more than mobo at full load. Do the math, it is IMPOSSIBLE for you to have air cooling and only a difference of 1c over your mobo. It just can't happen that way, the mathematics and the physics all scream NO WAY.
TLKfatman said:
just to let u know my cpu temps are 27c and mobo is 28c idle and 33 cpu and 30 mobo full load so ya u can do it
Delta = CPU temp - Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt (CPUw) that the CPU consumes, the HSF will limit the CPU's temperature rise to (C/W x CPUw) plus the temperature at the HSF's fan inlet. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that CPU temp will increase 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
BinarySuperman said:whoa whoa whoa, that cpu sensor is supposed to be touching the cpu??? i took my index finger and pushed the sensor back a little cause it was standing to high and my cpu didn't go in as well, are u sure it has to be touching it?
