- Jan 10, 2012
Ahh, a real question(s)!what does in use (compressed) mean?
committed?
cached?
paged pool and non-paged pool?
That may slow things down... there is a reason for things to be in RAM, some of that is quicker loading fo things again. May want to check that impact as it may have unexpected resultsI am trying to learn to gut win10, this is a fresh install with some stuff removed, sorta hacking I guess, I'm trying to get it to reduce it's use of ram and cpu.
I remember spending endless hours "fine tuning" XP. Every tip, trick and wacky mod I could find on the interwebz to make it faster and more responsive. I changed so many things that each (inevitable) reinstall took a week. Turned out I just needed to dump the crappy Pentium 4 CPU and get Windows 7. Lesson learned. LOL
When the installed capacity is being all used, indeed. Otherwise, if you aren't using it all or darn close to it, one will not know the difference.MOAR RAM has been one of the most effective PC speeder-uppers over the years
You can make a small RAM disk. Just wait until you get used to the speed of RAM.
Enjoy your tinkering! Report back with what you did and learned!this isn't about actually making it faster, it's about learning something new.
I can just stuff in the other 16 gigs of ram and let it go at that but I learn nothing from that.
and why yes, of course, every thing I take out of win10 just makes it all the worse, but that's learning!!!!
