- Oct 23, 2002
I'm looking for a heatsink that fits a 92mm fan for an AMD 2500+.
I love my Thermalright SK-7 so I would like to go with Thermalright again.
They have a few different heatsinks that fit 92mm fans, I dont know which to choose. I would like a fairly quiet setup so I figure a lower rpm 92mm fan would move a good amount of air while not being so loud. But how do these heatsinks do with quiet fans?
So between the:
SP-97
SLK-947U
SLK-900A
SLK-900U
Which is the best?
I notice most bolt onto the motherboard while some (900A) has the clips. Are there any disadvantages to having clips other than the obviouse less support for the heatsink?
If you have any success stories with any of these heatsinks equipped with a quiet 92mm fan please share.
Thanks.
So between the:
SP-97
SLK-947U
SLK-900A
SLK-900U
Which is the best?
Thanks.
