What is this and what does it do? When overclocking do you need to worry about this or just keep it the same. Its at 2.0ghz now and I dont know what it is....
The HT Link is the communications bus between the CPU, the northbridge chipset (NB), and the southbridge chipset (SB). PCIe video ties in at the NB and everything else (PCI, SATA, PATA, USB, Ethernet) ties in at the SB. Memory is NOT accessed through the HT Link. (see below)
Generally you do not need to overclock the HT Link and, if needed, you can actually reduce the HT Link speed down to 14-1600 MHz with little to no impact on system performance. If you're running high-end video in Crossfire/SLI then the default HT Link speed of 2000 MHz is needed. In extreme video configurations overclocking the HT Link to 2200 MHz may help but farther than that can hinder performance.
L1 and L2 are in the CPU cores. L3 cache and the IMC (Integrated Memory Controller) are both part of the cpuNB, which is part of the CPU. RAM is accessed through the IMC ...
