Hello guys,
I have another problem... I want to play Watch dogs but it gets roughly 40-50 fps on average on lowest settings 1920x1080. If i look up the benchmarks with an i7 4770k they give 85 on medium settings. I dont really know whatsup.
Hopefully you guys could help me out once again!
Thnx in advance
Quite simply put, you're not using a 4770K , the haswell has a much better IPC/IPS than any of the current AMD offerings. I benchmark on both AMD and Intel, Intel alwyas gives the best results in 3D benching. My only suggestion, if you want to get better FPS out of your AMD all you can do is up the core speed.
Didnt really find a stable ghz above 4.3. Might be the max for my cpu-cooler.
That's quite possible, check your CPU usage while gaming just to see what it's doing It might only use 2 of the 4 cores you have which might open up some room for you. If you disable a couple of cores you could most likely clock it a bit higher.
Look at it this way, If the game only utilizes 2 of the 4 cores then while you're playing 2 cores are just spinning their wheels and creating heat. If your cooler tops out at 4.3G with x voltage on 4 cores, typically it could clock higher with slightly more voltage and create a similar amout of heat that your cooler can still dissipate. IF you were able to run at say 4.8G with 2 cores you're going to get better throughput and higher FPS since the game only uses 2 cores. You just need to verify that first. It's possible it uses 4 and is just a poorly written port as Waza suggested.
EDIT: Well I looked up WatchDogs and apparently it is a multithreaded game so this won't help you at all.
That's whay the 4770k did so well since it also has hyperthreading. So it's essentially running 8 threads at the same time as opposed to your 4. It also has a high bandwidth L3 Cache whhere the A10 has none. I think you're just going to have to live with it for now and hope that they optimize it bit better.
Did a little search about Watch Dogs and there is some hoopla over the 14.6 beta druvers for ATI vid cards.
RGone...
It's not only CPU utilization that holds most console ports down, most of the time the code is just bloated or buggy or simply written the fastest and most resource consuming way to save costs.
There are thousands of examples of well and badly written code but it is true that unless devs put extra effort into optimization Intel CPUs will be faster.
If you compare watchdogs to GTA4, Wathcdogs world is more detailed/cluttered but GTA4 has better physics modeling and more attention to detail and in no way should watchdogs be more resource intensive on cpu side than GTA4. They both work on PS3 so they both have same hardware limitations. it's simply the quality of the PC port that limits the performance.
GTA4 never has been really great quality port either but it was decent.
I have been using computers since the late 1980's. I work in printing so we always had Macs. I have never, ever once heard of any OS, any application, any game. Anything for that matter being used as an example of well written software. Everything is bloated, poorly optimized, buggy. Are there any examples of well written code anywhere? AT&T Unix maybe.
Moving Windows 8.1 from HDD to SSD
http://www.tomshardware.com/answers/id-1857326/moving-windows-hdd-ssd.html
That thread was marked as "SOLVED" so the answer was in the thread.
The post by MMGN was marked by the OP as "best solution". He gives short explanation of how he used Easus Partition Manager 9.3 to do the Clone and Move to the SSD.
Note some of the later SSD's have software packed with them to "move" from HDD to SSD and
you could of course try that if it is with the drive. However I have used Easus software before and it is pretty handy and
works in the free version pretty well.
RGone...
