- Sep 13, 2012
- Okinawa, Japan
Hi, this is my first post on these forums. I've been planning a new rig -- my first serious build in some years. My last was only okay. This time I am planning to go a pretty big -- all told, $2500 including a 120 MHz monitor. Cost is still a factor, but I plan on getting some really cherry components. (I'm not claiming they are the super ultra best), I have been doing my research though and I like these products and I think they should work well together.
CPU: Intel 3770K (3.5 GHz /3.9GHz)
RAM: Corsair Platinum Dominator DDR3 1600 8GB x2
GPU: One EVGA 2GB DDR5 GTX 680 (wish I could get two - I might)
Motherboard: Sabertooth Z77
Storage: 2 200 GB SSD's (raid 0), and one 2TB 3.5" drive
Cooling: Corsair H100
The RAM is really what I am pondering. I like the fancy corsair RAM, but I could buy much more expensive ram with higher speeds if it was justifiable. My goal is to select a group of components that when put together, can each be used to their potential. (Yes, the ASUS supports much faster than DDR3 1600, I am ok with that) It seems the RAM can be overclocked as well. That leaves the CPU.
The Intel 3770K has an onboard memory controller that runs at up to 1600 MHz. Is that a hard limit, or can the memory controller of the CPU be overclocked as well?
Is it wise to pick RAM that exactly matches the processor's ability to support, in terms of the speed at which is accesses memory? Or should I offset it by the anticipated overclock margin, and then overclock it to match the best the CPU can give me?
