Hi !
I have upgraded my whole system except for the core components, and I need some advice.
I need some advice on which ram to buy.
Motherboard: Gigabyte GA-X58A-UD7, X58
CPU: I7 920 or I7 930.
Ram: 6GB of whichever suits the setup the best
I will buy a high end custom watercooling setup for the CPU, Motherboard and GPU.
I will try to overclock the computer as high as possible aiming for 4,5Ghz.
I don't want the ram to be the bottleneck, so I need some advice on which ram would help me reach my goal.
I have no particular budget, but I don't want to waste money on totally overkill. I want the best ram for my setup and overclock which will suit the purpose.
I'm not sure if a 930 will clock better than a 920. If you got opiniona on that to I would appreciate it.
I hope someone out there with experience can give me som advice.
