I have a mild overclock on my i7 3930k, just 4 GHz on Turbo. My motherboard is an Asus P9X79 Pro, so I downloaded the AI Suite. I would think that this being software made by Asus it would show the most accurate sensor readings. But browsing different forums I read that some people say it's unreliable, and it's better to use CoreTemp, Real Temp or one of the other sensor reading programs out there.
What this leaves me with the question, which program do I believe? Of all the people who say AI Suite is unreliable, are they just repeating what they read in forums, or is there an educated reason for saying it's not reliable?
I want to know because I don't care so much about speed as I do about stability and my CPU to last several years. I can't find anywhere what's the real TJMax temp for the 3930k, at least not a reliable source, because on Intel's website it only shows the TJCase as 66.8 and doesn't show TJMax. So depending on what forum you read, some people say it's 91 (which is what CoreTemp and Realtemp show as well) and some people say less than that.
After running Prime 95 for about 25 minutes, AI Suite shows me 58C; Real temp shows me 80, 79, 74, 75, 77 and 80 for each core. So we're talking a 20 degree difference here. Doing more testing with Real Temp and Core Temp both open show that they are about the same, with a 1 degree difference every now and then that is probably more due to update of the readings being off than anything else. AI Suite still lags 20 degrees behind both of them.
So how do I know which program to trust? And how can I find out reliably (not by what people repeat from others) what's the max safe temp for the 3930k that will not shorten its life?
