- Apr 19, 2012
I'll update my WTB ad in the classies to hunt for water cooling goodies. Reckon it'd be cheaper
Don't buy someone's used waterblock unless they give you all the parts. Chasing down brackets is non-sense.
I agree with Bassnut on the Ek 4.0 pump, I actually have that pump from an older wc setup. It works fine but it really doesn't have great head pressure and it makes a vibrating sound that can be annoying. The D5 Varios I have are set at #3 pumping speed and are nearly in audible.
As far as the Helix fans I also agree with GTXJB they are nice fans. Sometimes I feel people get the wrong impression on fans and take Db readings to heart. It's not always how loud a fan is but the quality of the sound. The helix fans can be heard at 100% but make more of a whoosh sound which is more pleasant then the chopping of some others. I also have BitFenix Spectre LED Pwm fans these to be exact. They have slightly less static pressure then the Helix fans but are equivalent in sound quality.
For a Cpu block, I like my Ekwb ones, I have the Ekwb Supreme Hf and the Supremecy. Having the universal fitting is nice, so if down the road you can swap it onto an Intel chip without buying extra parts.
100ml res is fine there are no real advantage to huge tube res.
on the res, if you are going to put a block on the gpu also you have to turn the pump up some, this can cause a vortex in the short tube res, it happens if the res is 100-125mm tall or less.
I use the 250ml bits power res, it's huge and very hard to mount in the case so i mount it on the back of my podium with my rads.
Good idea. I'd rather not buy all the stuff and not have enough or too much.My suggestion with tubing is get either 3/8" id x 5/8" od or 1/2" id x 3/4" od. I find the thin walled stuff kinks too easily! You may want to hold off buying bends until you have everything and visually see how you're going route things.
Those barbs and clamps I tossed in are all for 1/2" - 3/4" soft tubing. I was like you loved the look of ridged tube but it is ...... PITA especially if you tend to change parts or fiddle. The bends are brittle from heating even if you are just swaping ram you can break a bend or as in my case where a bubble was in my bend that started leaking which cost me 2 ASUS GTX560 442 core Video cards due to a leak.
FORGET about ridged ...... get some good soft tubing ...... Primochill seems to be the popular choice now I think GTX mentioned it above.
(earthdog!!!!!! the automagical is broken!!!!!!)
