- Sep 7, 2013
- Thread Starter
- #41
Sounds goodthe ek waterblocks are great, stick with that.
Good idea on the hot water / heat gun. It should help out with making nice tight fittings.clamps? I ain't got no clamps..... hey I don't use no stinking clamps.....
and i don't, all the leaks that I have had have all been at the stinking "o" rings and i have reduced those greatly by lubing them with pledge furiture polish, it's wax and keeps the rubber "o" ring from rolling while I screw the barb down to seal it then when I have all the tubes cut to fit I heat the barbs up good and warm with a heat gun and slip the tubes on, but clamps might make you feel better.
(earthdog!!!!!! the automagical is broken!!!!!!)
All the blocks are great. Which ever one you pick is fine, including the XL. Its all in aesthetics really.
I'd look to grab the smaller tubing with angled barb fittings as it will make your loop easier and look cleaner. The shortest and cleanest loop is more efficient.
Make sure when installing your reservoir, that your pump is being fed by the reservoir naturally. That's the only part of the loop order I would stress about.
Since you bought a 30 FPI radiator (GT Stealth), make sure you grab some REALLY high static fans. Now you're in the 2000-3000 RPM range. Don't grab the helix120s now since they are designed for low to mid FPI rads and not against a 30 FPI rad. Again, for that rad to run efficiently you'll need 2k-3k.
Also, make sure to add a drain (lowest part of your loop) to your loop to make maintenance easier.
I'll look around for some better fans. shouldn't be too hard.
As for the drain, I'll add a tee to the bottom of the res.
I say tee as in PEX tee. Yes, I talked to my neighbour who's a plumber, and he has agreed to supply any sort of fittings I need, he even gave me some sweet 1/2 PEX to use.
PEX ought to work for this right?
Harder to work with, but he's got the right tools for all the crimping I need for the connectors and bends
EDIT: Okay so if the cart on the last page look good, (the EK Supremacy MX block and BITSPOWER TANK Z-MULTI 150 the acrylic version) looks good, I'll order it up tonight.
