Ha! Fooled you all!
The answer is G for all of the above +Gir.
Option F got eaten...
I'm building a Gir-themed Multimedia PC because I have a gaggle of Anime and cartoons on CD-Rs that I really want to watch on the big screen TV in the basement without having to lug my machines down there. Also, only my main rig has TV-OUT.
But largely I just wanted a good (or plausible) excuse for building a machine in this case that I love so much. I got a great deal on an all-in-one motherboard that includes a wireless IR Keyboard/trackmouse thingy and I found an even better deal on a low-profile TV Capture card.
Either by dumb luck or divine intervention the chrome paint on the case actually improves the reception of the Infrared keybooard by bouncing the light into the hole where I've mounted the receptor. THat hole in the front of the case used to hold a front USB port, but it's leftover screw mounting holes (again with the luck) matched up with the holes on the IR receiver card.
The only part I need now is a moderately spacious hard drive with which I can house all of the video I record. 40-60gb should do it but I worry about that in a minute.
This machine is only a little bit bigger than a regular VCR and it's extremely quiet (21dba).
Here are it meager but acceptable stats.
- Celeron 466
- 192mb PC66 RAM
- SIS630 Flex ATX all-in-one motherboard with I/R receiver
- ATI TV Wonder capture card
- 52x CD-ROM drive (will be a burner once I upgrade the PSU)
Major irritations/set-backs thus far
- I will need to solder audio connections onto the motherboard because it lacks the audio jack riser.
- I will need to run 100feet of ethernet cable to the basement through the air condition return upstairs all the way to the basement. Otherwise I won't be able to use the channel guide feature of the ATI card.
- I have to cut a custom cable for the Infrared receiver because the one provided was too short to reach the front of the case.
- The Cable organization took 25 minutes. It's fairly difficult to keep them away cooling from fans in a case this small.
