- Feb 25, 2004
- N of splat W of Torin
I replaced my Modem and Router...It turns out the Router was good.
A nice Linksys WRT54GL
Questions
1)I always wanted to install open source firmware... Tomato or what not. Can I just plug it in my other PC and do it from there, it won't cause any problems having 2 Routers will it? I'll have the Wifi shut off.
2) Can I get some advice on what folks do with an extra router like this in a home environment. I would like to build my networking skills up and need something to work on.
3) I now have a Linksys WRT 160n v2 is it a good one? I would like to use the N. We got our first Laptop this Christmas...this one http://www.newegg.com/Product/Product.aspx?Item=N82E16834115544&Tpk=34-115-544
The specs say draft n (On the laptop specs), is there a way tell if its using it? The range is not all that great, if it is using it. Right about the same as the WRT 54GL.
I am new on Vista and Laptops what can someone recommend to improve the N. Maybe a Wifi card?
Price matters somewhat but I would prefer to get it from Neweeg.
Thanks for any advice.
Questions
