Yeah, MBM5, that prog and shutdown now saved my processor at least twice when my bong ran out of water. The shutdown now prog stopped working after awhile, it would just sit there and give me the "trial period expired" sorta reminder, and that doesn't help too much when your 1800+@1730 has about 30 seconds to live.
I installed it and rebooted as it stated. Once I started monitoring it only came up with one sensor and it said it was at 127*C????
Anyone know
1. Why it came up with only one sensor?
2. How I know what sensor measures what temps?
3. What the hell in my pc is 127*C?
LOL theres nothing at that temp or your cpu would be dead. You need to change the temp reading sensor. spend some time tinkering with mbm and you will find the right ones.
Anyone know
