winterlord
- Jul 22, 2013
i might get a better cooler in time but for now what is the best cooler for a i7 4770 for around 35bucks or under. will i safely hit 4.3ghz with a 35dollar cooler as well? at 1.25v or 1.2v
The 212 series used to be best bang for the buck but that's no longer true. There are several others as good or better for similar or less money.
No, it shows GAIA 1C worse.
That shows GAIA 2C worse.
The Performa is just over $45, which is more expensive than the 212 EVO.
Bottom line is, you aren't reading correctly.
@ ATMINSIDE, for the second one you have to make note of the ambient temperature and look for the delta. Which still shows the 212Evo ahead, but only by .4C (74-23.8=50.2 75.7-25.1=50.6)
Of note, Frostytech does not specify the ambient temperature, but it does beat it.
