I've only have my case for about 6 months and for the most part I've only been using my two Mushkin 3.0 USB sticks. I do have three Older Mushkin 2.0 USB sticks in 8GB/16GB/32GB versions also but I have not used them in a while. Anyway this past week I decided I wanted to use one. So I plugged it in the front USB 3.0 slots they are 3.0 cause they are colored blue and I have them plugged into the motherboard with the 3.0 cable that's part of the case.
So what happens is that whenever I plug the 2.0 sticks or any of the three they all either fail right away or during transfer of data from the HDD to the stick it freezes. Also sometimes the stick works okay and the file transfer works which is odd, but most of the time it don't work and I have to physically disconnect the stick cause the remove hardware icon by clock won't work and won't release the stick for me.
Here's the kicker though my Mushkin 3.0 USB sticks work fine no problems. I should mention though the 2.0 sticks do work fine in the back of the computer slots the ones directly on the motherboard both the 2.0/3.0 slots work fine with any stick. It's only the ones in the front that don't work with the 2.0 sticks.
So whats wrong, is the header in front broken somehow. I unplugged the USB header cable from the motherboard and back in and it's still not working correctly.
My motherboard uses a third party controller for USB 3.0 to work. It wasn't till Z77 boards that 3.0 became Intel native, not sure if this is a cause or not probably not. thanks
